A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185 Questions View all
No turning on when I plug the back cover
I broke the screen and replaced it with new one with frame, now the earspecker don't work and on the screen i have always the hands free icon, also when i plug the back cover the phone don't turn on.
Add a comment
Chosen Solution
Go back and tear the phone apart then clean the connectors with 90+% IP alcohol and a soft toothbrush. You should also make sure any rubber insulators are in the right place so when you put the back cover on your not shorting anything out. Make sure all connectors are together securely and that the connectors don't have any broken pins. Check the ribbon cables are not damaged or pinched . Hope this helps
LG G2 Teardown
Score 3
1 Comment:
Before post here i try to cleaned with ipa but with no success, i try again and voila the problem solved. Thanks!!!
by
Add a comment
The problem with the handsfree solved, also the problem with back cover solved with a piece of foam above the battery connector, was not make a good contact when put back the cover
Score 1
Add a comment
Add your answer
Fotis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 72
