Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Circuit board shorted. Help!
The little circle pin right under the battery connector has been shorted. Is there anyway to fix this? My iPhone is stuck on the Apple boot up screen. Thank you very much I have inserted a link showing the connection I am talking about.
https://www.dropbox.com/s/1dcoh6gg7s8iu4...https://www.dropbox.com/s/1dcoh6gg7s8iu4...
2 Comments
How do you know you shorted the antenna pin?
by
Would be great to know where exactly C5128_RF is on the board. I have an iPhone 6 which won't boot, seems to have short on VCC_main but it looks as though PP_BATT_VCC is shorted also. Could this be one short or 2 separate ones on different lines? Can I use current to test this cap for heat in the same way as on VCC_MAIN?
by
Add a comment
Chosen Solution
That is the lower antenna connector. What do you mean it is shorted? Is it physically damaged (making physical contact between the center pin and the outer circle), have you measured it with a multimeter?
You will want to check C5128_RF to see if that is the component that is shorting the line. Otherwise, if you have the proper tools and experience, you could remove the connector by de-soldering it to see if that is what is causing your boot problems.
Score 3
4 Comments:
I was told the connection was being attempted to be reconnected with metal tweezers with the battery connected and the tweezers made a spark. Now the phone won't boot up
by
Alright, that is something different. The outer antenna connector ring is ground. Right next to it are some test points for the battery voltage and Tristar detection of accessories. What probably happened is that the Tristar line was shorted and this could have damaged the Tristar IC.
This will require a board level repair that requires micro-soldering.
by
Hey @refectio sorry to drag up an old post but it relates to my problem. I found that C5128 is short to ground on 15 board I have laying around and the few I have looked into, appear to be the antenna switch, is this normal? Do they all need new switches?
by
I assume this is normal as I have tested some working boards and they are short too but work fine.
by
Add a comment
Well if you want to make it easy replace the logic board and sell the other one but DON'T THROW THE OTHER BOARD IN THE TRASH GIVE IT TO SOMEONE TO TAKE PARTS OFF OF!!!!!!!!!
Add a comment
Add your answer
matt k will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 3,631
