Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3664 Questions View all
Heat sink fan gasket
I am replacing the logic board on a Macbook Air 2012 13" i7 2Ghz 8 Gb A1466 and was wondering if the gasket between the heat sink and the fan serves any purpose other than theoritical. I have heard repair folks who say they leave these gaskets off. Just wondering what folks here thought.
1 Comment
I don't know......Steve Jobs' obsession with the aesthetics of even the unseen. Sure, Steve's gone, but still. Thanks for the reply.
by
Add a comment
Chosen Solution
I don't believe Apple would go to the expense for theoritical purposes.
Definition of theoretical
a : relating to or having the character of theory : abstract
b : confined to theory or speculation often in contrast to practical applications : speculative theoretical physics
2
: given to or skilled in theorizing a brilliant theoretical physicist
3
: existing only in theory : hypothetical gave as an example a theoretical situation
Score 3
Add a comment
I think it is to minimise any potential rattle from the fan, and to generally hold it in place. The rubber gasket is pushed down slightly by the bottom cover, which will push against the fan (haven't got one in front of me at the moment, so this is from memory). If this is missing though, it doesn't cause any issues, I think Apple were just being extra cautious.
Apple do a lot of things which don't make sense. For example, the taller logic board screw on A1398 models, which is covered by a rubber component, something else which is easy to lose. The hidden logic board screw on A1425 models and the weird change in battery design. Having no standard USB ports in the new MacBook. The list goes on...
Score 3
1 Comment:
Right, that makes sense. The bottom cover likely does cause some pressure on the gasket/fan. I previously had a fan rattle caused by that top lip of the fan being slightly bent, corrected by straightening, so not sure that pressure is always helpful. Thanks Reece.
by
Add a comment
Add your answer
Phil will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 21
All Time: 1,581
