Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
I can't get my wifi to turn on
When I touch the wifi tab to turn on wifi, it doesn't light up the bright green that it should. It then turns back off.
Score 1
Add a comment
1 Answer
Most Helpful Answer
Did you flash a custom ROM? If you did, that is probably your problem. If not, it might be a bad joint under the wifi chip but try a factory reset first.
Score 1
Add a comment
Add your answer
slmd4345 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
