Can You repair the screen of xiaomi 5s
it got in to water xD
jovan hanwan , Here at ifixit are volunteers to answer repair questions on various devices, we do not do repairs here. My advice is for you to stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, and disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage and if necessary will be able to change screen assy. If not wanting to do the repair yourself drop into a good local cell phone/computer repair shop, have them take a look and estimate repair. Good luck.
Yes, any phone is repairable. It might not be easy but its possible. And if "it got into water xD" Then there's probably more than your screen broken and you will most likely need a new phone.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 212
