Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
CPU TEMPERATURE on MacBook Pro
Is it normal for a intel 2.5 gHz (turbo boost to 3.1gHz) i5 (ivy bridge) in a mid 2012 MacBook Pro 13 inch to get up to 75 degrees C under heavy load?
Score 3
Add a comment
Chosen Solution
A little too much for this. You can easily get rid of this problem by replacing thermal paste.
How to remove the cooler from here
Thermal Paste
Score 3
Add a comment
First remove the fan and clean out the vent. MacBook Pro 13" Unibody Mid 2012 Fan Replacement
If the vent looks clean, look at the heat sink. See if there is an oily looking residue around it. It is liquid filled and can spring a leak and may need to be replaced.
MacBook Pro 13" Unibody Mid 2012 Heat Sink Replacement
MacBook Pro 13" Unibody Mid 2012 Fan Image
Guide
Difficulty:
Moderate
15 - 45 minutes
MacBook Pro 13" Unibody Mid 2012 Heat Sink Image
Guide
Difficulty:
Difficult
45 minutes - 1 hour
Score 3
1 Comment:
I did the thermal past but I broke the cable for the iSight camera oh well now the NSA will have a problem using my camera for there Optic Nerve program
by
Add a comment
100 Celsius is the limit. 75 under heavy load is completely normal.
You don’t need to replace your thermal paste. SMH.
Score 1
Add a comment
Whats your temperature now? @col117
Add a comment
Add your answer
Collin.nesbitt@gmail.com will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 9,760
