Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
iPhone 5 Not charging if the Dock connector is fitted in!
Hi Everybody, i'm trying with two differents dock connectors and both give the same results!
If the dock is fitted in, the iPhone doesn't recognize the cable. if i take out the dock... The cable works correctly!! How the f is it possible? LOL
I'm also trying without the speaker, without screws only one screw... ecc
Still no solutions O.O
Hope you can help me!
Thanks <3
Add a comment
1 Answer
Chosen Solution
...if i take out the dock... The cable works correctly!!
How do you know the cable works? Have you tried it on another device?
It is always possible that you have a defective replacement dock assembly, small parts are notorious for low quality. That said, I would inspect the area around the connector on the logic board to see if there isn't any damage, missing components or obstructions inside the connector impeding a proper connection.
Score 2
1 Comment:
Yep, of course the cable works, i've tried it on some different devices...
Don't think the replacement are defective and both with the same defect... i'm checking the cable "hole" and trying a lot of different positions for the connector but still nothin... :(
by
Add a comment
Add your answer
Alessandro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 70
