Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3215 Questions View all
Will changing the rear camera fix the digital shutter not opening?
Recently having a problem with the rear camera not opening. debating on buying a new camera, but wanted to seek out some advice first.And I have tried restoring and all that jazz, nothing works. has anyone tried this already? Thanks in advance!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
This is a hardware issue on Apple's part source.
I'm pretty sure you can bring it into Apple to get it replaced.
Score 1
Add a comment
yeah, there is no apple store where i leave. i brought it oversees. apple is bollocks
Add a comment
Most probably it will solve yeah. I've repaired quite some with the issue you describe and replacing the camera solved the issue.
One thing: if the problem is with the front camera it can also be that the shutter won't open at all so in some cases a broken front camera can cause this problem. If you want to be absolutely sure just replace them both.
Add a comment
Add your answer
Joshua will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,126
