francis levesque you'll have to find the CCFL to match. there are no part numbers available unless you can find the datsheet for the panel. The CCFL for your panel has the following specs:
Lamp Position:
Edge light type (Top and Bottom)
Lamp Type:
CCFL
Lamp Life Time:
50K(Typ.) (Hours)
Interface Type:
Connector
Lamp Driver Board 1:
4 pcs
Lamp Amount:
4 pcs
Lamp Shape:
Straight
Lamp Voltage:
666/750/825V (Min./Typ./Max.)
Lamp Current:
3.0/7.0/7.5mA (Min./Typ./Max.)
Lamps Power Consumption:
22W (Typ.)
Backlight Interface (Brand):
YEONHO
Backlight Interface (Model):
35001HS-02L
Backlight Interface (Pin Pitch):
3.5 mm
Backlight Interface (Pins):
2 pins
Backlight Interface (Amount):
4 pcs
Backlight Interface (Configuration):
BLL-2PINS-HL
Lamp Operating Frequency:
40/55/60KHz (Min./Typ./Max.)
Lamp Startup Voltage:
1300/1700V (Min.)(Ta=+25/0℃)
Okay, so here is the datasheet for the panel AUO M201EW02 Datasheet slightly earlier version, same backlight CCFL Now you can contact places like this or on here to see if they can match you up.
