Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Questions View all
Where to find CCFL number
having trouble find the right ccfl to replace mine so where can i find the right one or serial number or whatever it's call
imac early 2008 20'' LCD AUO M201EW02 VB
Mise à jour (23/02/2017)
will this fit it says it is for the proper sreen http://www.lcdparts.net/CCFLDetail.aspx?...
here if you look you'll find the matching no. whit the screen that goes to the previous link http://www.lcdparts.net/CCFLS3D.aspx
Add a comment
Chosen Solution
Hi,
To add to the @oldturkey03 comprehensive answer and also using the information supplied by you, here is a link to another supplier. Select AUO in Sort by Brand box, scroll to the bottom of the list and select p.3 of the lists 1-4. then scroll down to find M201EW02 and click on 'detail' link for more info, (3rd from the bottom of the list on p.3).
Score 2
Add a comment
Most Helpful Answer
francis levesque you'll have to find the CCFL to match. there are no part numbers available unless you can find the datsheet for the panel. The CCFL for your panel has the following specs:
Lamp Position:
Edge light type (Top and Bottom)
Lamp Type:
CCFL
Lamp Life Time:
50K(Typ.) (Hours)
Interface Type:
Connector
Lamp Driver Board 1:
4 pcs
Lamp Amount:
4 pcs
Lamp Shape:
Straight
Lamp Voltage:
666/750/825V (Min./Typ./Max.)
Lamp Current:
3.0/7.0/7.5mA (Min./Typ./Max.)
Lamps Power Consumption:
22W (Typ.)
Backlight Interface (Brand):
YEONHO
Backlight Interface (Model):
35001HS-02L
Backlight Interface (Pin Pitch):
3.5 mm
Backlight Interface (Pins):
2 pins
Backlight Interface (Amount):
4 pcs
Backlight Interface (Configuration):
BLL-2PINS-HL
Lamp Operating Frequency:
40/55/60KHz (Min./Typ./Max.)
Lamp Startup Voltage:
1300/1700V (Min.)(Ta=+25/0℃)
Okay, so here is the datasheet for the panel AUO M201EW02 Datasheet slightly earlier version, same backlight CCFL Now you can contact places like this or on here to see if they can match you up.
Score 4
2 Comments:
@oldturkey03 you constantly amaze me!
by
Hi francis levesque,
Contact the seller and confirm with them which is the correct one
http://www.lcdparts.net/contactus.aspx
by
Add a comment
Add your answer
francis levesque will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 238
