Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Questions View all
Black screen, no power
Hello guys,
So I have a Imac mid 2011 i5 2.7GH/z that dose not power up. I have reset the pram and changed the bios battery out just to be sure.
For diagnostic LED's I get LED1 solid and LED2 will blink once every 4-5 seconds (this causes the fan to power up for half a second).
Note the LED2 is blinking by its self, without the power button being pressed.
I have tested the power button to make sure that its not stuck or anything silly. Also maybe worth noting is that if a usb stick with a light is plugged in the usb stick will flash at the same rate as LED2.
I am unsure as to if this is a logic board or a psu issue and hoping that someone has seen this issue with LED2 blinking with no power button pressed.
Thanks for any help you guys have.
Add a comment
1 Answer
I hope this helps with your iMac.
https://youtu.be/xYmtoaT9ImI
Best wishes!
Add a comment
Add your answer
lee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 114
