iPhone 5C -Water Damage - REPAIRABLE?
Hello... i have an iphone 5C that had water damaged... does not turn on... no charge... opened it and saw a little rust inside. Do you know if iphones with water damage repairable?
Neil ChoyAxxx Clavano , You can always try to save the device. I will post links below that may aid in you recovering your 5C. 1st link is a guide explaining how to clean the device from liquid/corrosion and the 2nd link show how to disassemble the phone to access enabling cleaning of components/connectors,etc. Good luck.
Thank you .... I am hoping it can be fixed as it has pictures and files i need access to. Just worried as it seemed like there is definitely significant damage. I am not familiar on fixing phones but would like to learn how to. Any particular replacements parts i need (LCD, BATTERY, etc.?
Neil ChoyAxxx Clavano , It is always wise to get a new battery when water damaged has occurred, other then that it is pretty hard to say. When cleaning the phone scrub/rub gently as you do not to dislodge delicate components from the boards. Good luck with your device.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 165
