Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Touch Screen Non responsive
Working on a phone and replaced the screen due to it being cracked. Screen comes on as expected just not responding to touch. Was able to get it to work a couple of times before by restore but now nothing is happening.
Any help would be appreciated.
2 Comments
tried putting a new screen on it ?
by
Yes, to no avail. I think it is the Touch IC issue.
by
Add a comment
Chosen Solution
If you tried a different known good screen, then you probably have a failing touch circuit, and the touch ICs being the most likely (though not the only) suspects.
Search for "iPhone 6 Touch Disease" and you'll know what I mean.
Unless you broke the connector or pried something off the board, you have no responsibility whatsoever in this failure.
Because if the touch ICs themselves are failing, the reason is probably repeated drops or bends or sitting while the phone is in the back pocket. And/or the drop that caused the screen to shatter triggered or worsened the issue. All this caused the touch ICs to have connections that separate from the board, causing intermittent failures then no touch.
The most durable fix is to replace or reball the touch ICs, while repairing any potentially weakened traces. Then reinforcing the frame of the iPhone board to make it less prone to flexing.
This repair is certainly doable as any respected technicians has seen a lot of them.
But it certainly is not for a DIYer since you'll need very specialized tools and excellent control and skill to repair it. The touch ICs are packed close to a lot of critical components, and the other side of the board is populated by the CPU. Extreme care must be taken during the repair.
Some people place shims or electric tape between the board and the housing, to press the touch ICs onto the board.
This may constitute a temporary fix at best, but we've seen that it often results in failures that are harder to repair. This pressure is causing extreme stress on the board and causing traces to brake and more failures to happen.
Score 5
1 Comment:
Thanks. This makes sense since I tried a Known Good Screen.
by
Add a comment
There are couple of things that could be happening, first check the connectors on the screen and logic board to make sure you haven't damaged any of the pins. If they are undamaged then check to make sure the digitiser connecter is being correctly inserted into the board connector. If there is no damage and the screen is correctly connected then you may have a faulty screen.
Score 1
Add a comment
Add your answer
Jonathan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 439
