Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iPhone 6S home button "sticking" after screen replacement
Hey All!
So I have a peculiar problem, been looking through the forum but I haven't found one like this. So I through another screen on my iPhone 6S- the Touch ID is functioning (thank God) but when I tighten the pentalope screws the home button "sticks" I can barely depress it. Everything else is great! But that is super annoying, if I loosen the screws I can press the button, but that's no good because they will eventually fall out.
Any ideas out there? Thanks!
Score 1
Add a comment
Chosen Solution
Bend the home button Metal plate away from the home button. E.g I think it's called concaved.
The middle part of the metal plate needs to be further away from the home button.
That should fix it as I have been doing it for 5 and 6 series.
Score 4
4 Comments:
Thanks!- are we talking the plate that shield the button? Like the one that you screw over it?
by
Worked like a charge- genius!
by
Clarification for others:
The metal plate behind the homes button that is held by 3 screws.
by
It worked. Thank you Ben :)
by
Add a comment
Thanks I can’t believe I never thought to bend the bracket to correspond with non oem parts
Add a comment
Add your answer
Trevor Mecaskey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,707
