Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
MB doesn't turn on after RAM upgrade
I am trying to change/upgrade the RAM of a MacBook 2.4GHz Intel Core 2 Duo from the original 2GB (2x1GB) to 4GB (2x2GB).
The new RAM I bought are Corsair 2GB DDR2 800Mhz .
Now, the Mac with the new 4GB of RAM doesn't boot up (nothing, apart the light display on the corner down on the right).
If I keep 1x1GB (original) and 1x2GB (new) it boots up (since I tried all the combinations, all the RAM works fine).
Any Idea? Thank you
2 Comments
Let's first correctly identify your machine as there were 2008 & 2010 models of the 2.4 C2D machines.
by
Hi Mayer, thank you!
it is a 2008 (is 2242 Model, http://www.everymac.com/systems/apple/ma... )
by
Add a comment
Most Helpful Answer
Try another brand. I've had Mac compatibility issues with Corsair personally. I switched to Kingston and Crucial, and haven't had any issues.
Also the speed absolutely has to match. Any faster it likely won't boot.
Score 1
Add a comment
if is that the right model, you need pair of 667 MHz DDR2 SDRAM (PC2-5300)
of course both 800 Mhz didn't work, nice try:))
good luck
1 Comment:
I was afraid, it could have been that...I will try with 667MHz.
Thank you!
by
Add a comment
The RAM you are trying to use is incompatible with your model . You are trying to use 800 MHz RAM when that model only supports 667 MHz (PC2-5300). The reason why it works when you use the new ram in combo with old RAM, is that the old RAM is compatible. I am willing to bet if you looked in system specs, the Motherboard would only see your old RAM.
3 Comments:
Well, in the System specs I can see both, the new one and the old RAM (but it maybe doesn't support both 800MHz RAM .
Thanks!
by
RAM Type: PC2-5300 DDR2 Min. RAM Speed: 667 MHz
Details: Supports 667 MHz PC2-5300 DDR2 SDRAM.
Standard RAM: 2 GB Maximum RAM: 6 GB*
by
Thank you, Mayer
by
Add a comment
Add your answer
luthdo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 174
