Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Keep getting Error 4013?!
The phone has had its screen replaced. It has also been water damaged. But! It has been repaired twice and has been working fine for weeks and now it suddenly powered off and is now stuck at the itunes restore screen. Tried restoring with multiple different cables on two different computers and it just keep coming up with error 4013. Help?!
Add a comment
Chosen Solution
Error 4013 is usually NAND related but can also be caused by a whole bunch of reasons. Considering your phone was previously water damaged, the error is probably a latent issue that just now appeared.
Was the phone ever properly decontaminated (ultrasonic bath etc) or was it just dried...and heaven forbid, left in rice?
Other than a good visual inspection (you may find some obvious issues) or changing the battery as Ben suggests, I think you should look for a pro that does water damage and micro-soldering repair.
Score 3
3 Comments:
Haha not rice, but 99% isopropyl alcohol bath yes, no ultrasonic. I own a cellphone store and have years of experience but nothing is fixing it this time! Guess it may be a microsoldering job :/
by
No offense intended about the rice, I didn't notice your were a tech. Yeah, probably a logic board issue. Do you have the tools? You can check out my profile or that of several other regular micro-soldering contributors here.
by
Oh none taken! :) But okay thanks!
by
Add a comment
Most Helpful Answer
Try another battery. It seems the 4013-4015 iTunes restore errors have been fixed a lot by replacing the battery with another one.
Score 3
1 Comment:
wasnt the battery this time, but thank you
by
Add a comment
Add your answer
Austin Harris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 16
All Time: 717
