Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
display flickering and rebooting and freezing.
I have a 3GS, sometimes its display starting to flicker and rebooting the phone. after that, it is really hard to switch on the phone, it shows apple logo and starting to flicker again.
http://twitpic.com/39mjs0
http://twitpic.com/3aws5b
when flickering start on boot screen as the above shown pictures, it cannot be switched off by pressing the power button, I have to hold home+power button to turn off the display.
after about 30mins when I try to switch on the phone, it boots normally and come to home screen without any issues. but after a about 5 - 10 mins it starts to flicker again and phone is rebooting.
I would really appreciate if anyone can give an idea what causing this problem.
Score -1
Add a comment
Chosen Solution
Looks like a cable's loose, use this guide to take out and put back the display.
1 Comment:
ok thank you.. ill try this and let u know.
by
Add a comment
Use without charger
You might have the original charher
Update
Use without charger
If problem solve it may be that you are
Not using original apple charger
Add a comment
Add your answer
viraj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 5,630
