Washer wont fill with water
First washer wouldn't spin and drain finally got it to drain now wont fill with water can hear motor on if I wiggle the drum noise stops for few moments but still nothing so unplugged it
Score
0
Are you getting any error codes?
by mayer
What is the exact model number of your washer?
The motor should only be running if it is draining, spinning or agitating, unless a final rinse is being dispensed during a spin cycle. If the washer is filling, you will usually only hear the click of the solenoids from the water input. If you hear a motor spinning and nothing else is happening, I would turn the unit off and try to switch the cycle to see if that fixes the problem. If it does, then I would suspect a bad timer. Let us know the exact model number, and we may be able to offer more troubleshooting advice.
by Geoff Ice
