Small jumper location identification
I purchased for an iPhone 5S a Power On/Off Lock Mute & Volume Switch Button Flex Ribbon Cable and tried to install it myself.
Everything went OK except one small jumper that fell-off and now I cannot identify its location.
It must be located in the upper part of the chassis between back camera and vibrator.
This jumper is 0.8cm long, color is black and difficult to read a number 486 (I believe) on it.
One end is closed for a screw to fix, the other end is open for the screw to fix and both ends of this jumper are twisted at 90 degrees.
Thanks in advance for your answer.
3 Comments
@vel_1 your description is good but very non-specific. Post some images of what you are referring to with your question. Use this guide Adding images to an existing question for that.
by oldturkey03
Does the phone still work?
by Gigabit87898
Yes partly and turn-on, no sound and may be other problems.
by Vel Palassis
