Disassembly and repair guides for a wide variety of cameras.
VTech camera Wrong voltage
I connected to VTech camera the Wrong voltage . I connected 12v instead of 6v
And suddenly a small something sparked
What do I change?
Is it a fuse ? .....?
Please help
Thank you
Add a comment
Most Helpful Answer
Amine.Hakik most likely not a fuse. You will have to open it up and take a look at it. There are no routine parts that fail with over-voltage. Post some images of what you see with your question. Use this guide for that. It will allow us to see what you see. A good model number will also help to try to sort this out.
Score 1
Add a comment
Wow. Thank you guys for answering so quickly. I'm impressed
1 Comment:
The 1st pic
Bottom of the camera where it shows the model #. See the tiny screw driver ,where its pointing is where the small spark came out of. Thanks again
by
Add a comment
Add your answer
Amine.Hakik will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 110
