Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Bluetooth can't be turn on. No toggle - loading icon instead.
Hey!
I'm recently experiencing an issue with my customers iPhone 6 Plus.
The problem is if you go to Settings -> Bluetooth you can only see the Bluetooth heading and instead of the enable/disable toggle switch there's some kind of 'loading' icon. It just keeps spinning forever.
Already restored it, installed latest firmware through iTunes (both normally and through DFU mode), tried reseting network settings alone - none of these would work.
Any clues?
Score 1
Add a comment
Chosen Solution
Wifi antennae
iPhone 6 Plus 5GHz Wi-Fi Antenna Replacement
Replace a torn or missing Wi-Fi antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi service. Image
Product
$23.99
Score 3
3 Comments:
Thanks for response imedic! Also thought about it but wifi itself is working fine. Is it possible that only one of these modules is damaged on the antenna part?
by
That is kinda strange, did you recently update iOS? Also try resetting your network settings
by
That's another example of trying to replace the tires when your car won't start.
by
Add a comment
Bluetooth chip problem, replacing the antenna will not help in any way.
Get someone to diagnose and repair the board for you.
Score 1
Add a comment
I have the exact same problem. Did you find any solution?
Add a comment
Add your answer
ddomanski94 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 521
