handset outgoing voice not working
I have three handsets on this Uniden Cordless DCT-646 phone.
Two of the handsets are working without any problems.
Recently, since last one month, one of the handset has this problem:
when someone calls from outside or I try to call anyone, the call goes
through O.K. but other party can not hear me. I can hear them all right.
Rest of the functions are fine.
How can I fix this little problem?
(One more thing: I tried to replace this defective handset, and replaced
with a new one. After charging the phone for 24 hours, the same problem
of outgoing voice was detected on this new phone. I have installed a new
battery on both the handsets but the problem is not corrected.)
Please help.
Thanks!
Kulin Mehta
ksmehta@aol.com
Score 3
4 Comments
I'm having the SAME PROBLEM withe my PANASONIC!
by
Aug 10th, 2019!!!
by
My uniden landline phone is having a problem. We cannot hear through handset. Nor we can speak through the handset. We have keep speaker on and use the phone. Dial tone also doesn't come to handset. Can any body please give solution
by
Hi @ts2111
What is the model number of the phone?
Has the phone been "registered" with the base station (where the speaker is) that the phone line is connected to?
by
Add a comment
Chosen Solution
I tried your tip as suggested on my phone but unfortunately, it did not work.
Uniden Tech. Support also sent another suggestion:
Disconnect the Battery from phone and after a few minutes, connect it but while doing that
pressing * and # buttons simultaneously. Then charge the phone.
This tip also didn't work.
Then I ordered a new (Used) handset from Ebay and surprisingly, this one also had exactly the same problem as the old one I have. I charged it fully and inserted a new battery but nothing helped.
So now I will have to go on with two handsets which are functional or order another handset.
Thanks again for your help.
If you think of anything worth trying, please let me know.
Kulin Mehta (Philadelphia)
Score 2
Add a comment
Most Helpful Answer
Hi,
Try de-registering the handset and then re-registering it with the base station and see if it resolves the problem. If that doesn't work try resetting the system by "replacing" the base setting and registering all the handsets again with the base station.
Here is an image taken from the user guide that shows how to do this. (Click on image to enlarge for better viewing)
Update (03/02/2017)
Hi,
If you are willing to try it, here is a test which hopefully will help to isolate the problem. You may have to mark the handsets somehow so as to not get confused as to which ones were good or were faulty before you begin the test.
De-register the apparently faulty handset and also one of the good handsets, so that you only have the 1 good handset registered with the base.
Prove that it still works OK by making or receiving a call.
If it is OK then re-register a faulty handset and see if it now works OK and if the still connected good phone still works OK as well.
If the faulty handset still doesn't work properly, de-register it and register the other apparently faulty handset and see if it works properly now
If they both now work OK(i.e one formerly faulty handset - either one of the two that you have - and the good handset) then re-register the other good handset and see if it still works OK as well.
If the good phone now doesn't work properly, but the formerly faulty handset still does, then there is a problem with the base unit accepting 3 devices correctly.
Score 5
4 Comments:
Many 'Thanks' for your answer. I am going to try it today and get back to you.
I could not try earlier due to some computer problems.
by
Many Thanks, I will try this latest suggestion you sent yesterday.
I will try to update the status in a few days or a week.
by
I followed your suggested steps which did not work. Actually one handset could not be re-registered.
In the meanwhile, I received a replacement handset, same model number which I ordered last month.
Again, if you can believe, it is OK with all other features, but no outgoing voice, i.e. I can hear other party but they can not hear me - exactly same problem as I started first time. Two new handsets showed same problem after full charge with new battery.
Now I am going to switch to Panasonic in place of Uniden. It is weird, why only this function is affected in any new handset I tried. Now I have two handsets which are working and two which are not.
Thanks for you help. I really appreciate your time and tips.
KSMehta
by
Hi,
Was it the 'faulty' handset that wouldn't re-register?
I still believe it to be a base station problem. The only way to prove this though is to try it with another base station. You might be able to pick up one cheap on Ebay etc. As long as it is the correct model of course.
by
Add a comment
My phone did exact same thing. I unplugged phone battery unplugged power to base plugged battery back in on phone then set phone on the base..then plugged power cord into base with phone sitting on the base…worked….hope you have same
Score 1
1 Comment:
This worked for my Uniden DECT 1015 handset.
Thank you for sharing this solution.
by
Add a comment
Both my handsets lost voice microphone after 4 years of working great . Tried taking both batteries of out the 2 handsets and unplugged base for a few minutes, put batteries back in and plugged base back into wall outlet and put both handsets into base and now working perfect again! Not sure why this happened but I'm so happy to have 2 working phones again.
Add a comment
This is for the Australian owners of Uniden 6.0 phones.
Today we had a problem with our phones. WE could receive calls and make call and would get a connection. However the party on the other end could her us we could not hear them.
I tried every method on these help pages the even faintly resembled my issue. Nothing worked. I was about to throw in the towel when I decided i would shut my PC down, disconnect it from power and restarted. it.
I did it because here in the land of the Kangaroo we no longer have a land line and therefore we do not have an emergency phone. The phone signal reached our phone sets thru the computer. If the NBN is down your on your own with out a mobile phone. So it is a good reason to dispense with the almost a land line option.
If your hearing impaired thou it is hard to use a mobile phone with hearing aids. Additionally when your phone reception is poor to next to nothing where you live the mobile phone is not that handy of a gadget. Any why i have regressed. When my computer finally came up and all the lights returned all phone operation was again operating in a normal mode.
This may or may not help anyone but I hope it does. It was a last option for me and did not show up on and question I saw about the problem.
The bottom like is the phone was not working. I reset the computer and the phone was working. none of the other answers remotely indicated the network or modem as being the source of the phone issue. God bless you all. TBO49
1 Comment:
Hi,
In the original question the user said that 2 out of the 3 connected handsets worked OK without any problems and on only one did they have the problem of cannot be heard.
I don't think that a modem or network problem would be an issue in this case
Cheers.
by
Add a comment
Add your answer
Kulin Mehta will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 141
All Time: 27,792
