Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Small Metal Part Fell Out?
I was replacing my brother's iPhone 5 battery and after opening the screen panel a small metal part with two holes fell out and I have no idea where it goes. Also, this black strip towards the home button appears loose and I'm not sure where that goes, either.
Photos below:
https://goo.gl/photos/cRzqfSffKxCntwVE9
Add a comment
1 Answer
Chosen Solution
the small metal part on the left hold the home button flex in place once you connect it. is there a screw on the home button flex to the right when you're looking at the back of the lcd? if you lost if you could just use a bit of double sided tape I guess where the screw ought to be.
Update (01/26/2017)
you're welcome, you could even forget about the metal part, it won't matter anything if you do, it's a headache to put back. I do it for customers of course but if it was mine....depends on my mood if i were to put it back. it needs to first get set into the top area, there are two notches in it then forced down towards the bottom. you're welcome!
Score 1
1 Comment:
Ah, I see! Thanks for the insight. It appears I lost the screws but I will definitely try tape. Thanks again!
by
Add a comment
Add your answer
Hannah D will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 149
