Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Questions View all
Is it okay to replace HDD to SSD and also the battery?
Hi all,
I don't know if this question is silly but I'm planning on changing my default HDD that comes with my laptop with a Crucial MX300 SSD in a couple of days and I was wondering if it would also be okay to replace the battery straight after the HDD replace before putting the back cover on? Since my current battery has had the "Service Battery" prompt for a few days now.
Cheers
Add a comment
1 Answer
Chosen Solution
I'd do one thing at a time, so that if you do have a problem, you know where to look.
On the battery, I'd download and run Coconut Battery to get a much better idea of its status.
http://www.coconut-flavour.com/coconutba...
Are you currently having any issues with your old hard drive. (the hard drive cables on this machine are known to have issues.
When doing upgrades and repairs, do the problem first, then the upgrade. Just don't put the screws in the bottom cover so that getting back into it is no issue.
Score 4
2 Comments:
Thanks for your reply!
I have coconut battery installed on my laptop and its status tells me "Check Battery." It's capacity is currently 78.5% (5419/6900 mAh) of the original and doesn't last as long as it shuts down when the battery gets to around 25-30% charge.
Additionally, there's no issues with my old hard drive, none that I know of so far as it works just fine. I merely wanted to upgrade it to an SSD to boost performance really. Whilst I'm in the matter of SSD, would you know by any chance if I should have TRIM enabled as soon as I have the SSD installed?
Also, if I do run into trouble with the hard drive cable - I'm quite unsure if my machine is eligible to have it replaced for free by Apple?
I appreciate your help!
by
Cacles don't cost that much and go to the 2012 cable.
by
Add a comment
Add your answer
smberd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 82
