Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
lcd screen does not respond on right corner
previous screen this phone works fine, but when my cell phone fell to the floor the lcd screen is not cracked but, the lcd screen is not respond on right corner. i dont know what should i do for this problem to fix my phone, should i change the lcd screen or not? anyone can help solve this problem? thanks before
7 Comments
Reseat the screen connections for the screen. If it still does not work then the screen has gone bad (make sure to unplug battery before doing so.)
by
@benjamen50
i have doing that, unplug and plug it again the lcd connector but i forget to unplug the battery before doing that. whether there will be a problem?
by
It's recommended you unplug the battery because blowing the backlight circuit is a possibility if it's still plugged in.
Anyway you can conclude the screen has gone bad.
by
okay thanks @benjamen50 it means I have to replace a new one lcd?
by
Yes. New screen. LCD is fused with the digitizer.
by
Show 2 more comments
Add a comment
1 Answer
Chosen Solution
Hi Luthfie,
Take a look at this guide, step 14, to reseat the connections, like Ben recommended.
I think Ben is right. If you have followed Ben's instructions but the problem is still there, you have to replace the digitizer/LCD. The corner that is not working any more might be the corner that hit the ground. So, this part of the digitizer might be gone.
I would like to encourage you to at least try a repair yourself. You don't need to be a real professional to do that. Just follow this guide here on ifixit. Give it a shot! Always keep in mind: First switch of your iPhone and then remove the battery next.
Score 2
Add a comment
Add your answer
Luthfie Rachman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 98
