Computer does not turn on
I have tried all the procedures indicated in most of the Forums and the computer does not turn on. The Magsafe light is not solid green.
The problem might be in the proper logic board or in Magsafe DC in-board. In order to test whats is happening, you should disassembly the logic board. Before installing the motherboard back into the case and connecting anything, plug in the AC adapter into the MagSafe board.
The LED on the power plug has to turn on and remain solid green. If the LED lights up, you can continue assembling back all the components.
If the LED doesn’t turn on, try reconnecting the MagSave board to the motherboard and test again.
If still there is no LED light, it’s possible the MagSafe board was damaged and has to be replaced.
Any other suggestions about how to test the Logic Board and the Mag-Safe Board?
