The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Questions View all
Can I install a 16GB motherboard in an 8GB unit?
Samsung galaxy tab 4 7.0: Wondering if I can upgrade the internal memory on this unit by just replacing the motherboard. The charging port is bad so I was going to install a new board and thought I could upgrade at same time. Is this possible with out any other issues or software problems?
Add a comment
Most Helpful Answer
deslyper that is actually the only way you can increase your memory. Yes, you can install a 16GB board in your 8GB case.
Score 2
2 Comments:
@oldturkey03, don't you mean storage, not memory?
by
yes I was referring to the flash storage but stayed in the same jargon as the OP so as to not confuse things;-)
by
Add a comment
Thank you for your info. Will I need to load any operating software on the motherboard? Or is it just plug and play?
Add a comment
Add your answer
deslyper will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 130
