Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
How to fix dented iPhone corners?
I have an iPhone 5s screen which was dropped and the screen was shattered. The phone was dropped on the top corner and is now dented slightly inwards, this is causing a problem when trying to replace the screen as it isn't sitting properly in the frame. I don't want to force it in as I don't want to break the new glass. Are there any suggested methods to re corner the frame?
Score 1
1 Comment:
You could see if a local store has a tool in stock called a gtool. This is used to bend out dented frames.
Or you could shave down the dent with a metal flathead screwdriver.
by
Add a comment
You could always buy an new chassis for the phone. They can be a little pricey but also allows you to customize the phone with a wide selection of colors. Check out iphone4parts.com. I will post the link that goes directly the part your phone uses.
http://iphone4parts.com/shop/iphone-chas...
Here is one much cheaper on ebay.
http://www.ebay.com/itm/New-Space-Gray-i...
Alternately, you could search for other bezels or chassis on ebay.com, amazon.com and also aliexpress.com.
Add a comment
This tool works great on iphone and ipad corners https://youtu.be/pea1NOk2UKQ
Add a comment
Add your answer
Stelios Sgoutas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 9,721
