The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
46 Questions View all
clicks but only turns over sometimes
I drive a 91 Honda accord dx and I have replaced my starter about 6 months ago and I took it out to have it tested and everything passed. When I turned the key it would click so I would keep turning it because if I did it enough sometimes it would try to turn over and then stop and sometimes it would start but rarely. I have to compression start my car to get it started 98% of the time. Just wondering what it would be. I don't want to have to check all the switches and wirings just to find out it was the last thing I tried.
2 Comments:
Hi,
Try connecting another car's battery to your car's battery (battery jumper cables) and see if your car starts OK? (do not have the other car's engine running when you do this also do not flatten the other car's battery either if it doesn't start after two or three attempts stop and remove the cables, cables are +ve to +ve and -ve to -ve between the two batteries)
If it does then perhaps you need to get the battery checked? Also have you ensured that the battery cables are securely fastened and not loose?
by
My battery is brand new and I have a radar detector that tells me the exact voltage as soon as i turn the key to aux. I have even tried jumping it thinking it was the battery and nothing happened
by
Add a comment
1 Answer
Babygirl, Wow, OK. Is it really oily/greasy where the starter bolts up? Starter won't get a ground if it is oily between starter and the where it bolts to engine. Have the battery cables checked. Sometimes the corrosion is inside the cable housing and can't be seen. Just make sure the cables where ever they connect at both ends are clean (especially the ground).
Now after all that said, with new battery and new starter being checked out fine. There is only the power delivery left! My guess is that one of the cables is not making good contact or corroded inside, There by not letting the full voltage to get to starter. Hope that makes sense. Good luck and please let me know what you find even if it's not this.
Add a comment
Add your answer
babygirl143love will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 219
