Repair guides and support for top and front loading Whirlpool brand washers.
425 Questions View all
Front loader leaks water from top and bottom on spin cycle
1 Comment
Robert Sumsion what make and model washer is it? "leaks water from top and bottom" top and bottom where? Door?
by
Add a comment
1 Answer
Most Helpful Answer
Cause 1
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 2
Tub Seal
Score 2
Add a comment
Add your answer
Robert Sumsion will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 503
