Water not heating after I replaced the heating element and thermostat.
Hello, I replaced my heating element and thermostat and the water is still not heating in the dishwasher during the wash cycle. The heating element gets hot on the dry cycle though. I'm at a loss.
4 Comments
Are you getting any error codes?
by
None at all.
by
Could you confirm that this is a Sears or Whirlpool model GU2800XTVS2?
by
It's a Whirlpool.
by
Add a comment
Most Helpful Answer
browns41980 see if you can run the diagnostics
Score 2
2 Comments:
I'm going to attempt this tonight. Seems pretty intense, wondering if I should just call a repair guy now.
by
browns41980 I wouldn't just yet:-) at least give it a try and see what you come up with.
by
Add a comment
Try turning it off for 5 minutes and then turn it back on. This should generate an error code if there is one. Your symptoms sound like a problem in the control box. If the heating function works on any setting at all, that indicates a failure in the control box because it is the control box that directs heating when a particular function is selected.
There is usually some combination of keys that will do a reset of the micro-controller. When the micro-controller makes an error you will get some strange combination of failures. Unplugging the machine and waiting a few seconds before plugging it in again will probably cause it to do a reset. There is an outside chance this may have some effect on your problem.
Score 1
3 Comments:
Just unplugged for 5 minutes, plugged back in and no lights are flashing. How would I know if there is an error code?
by
Could you confirm the model number on that dishwasher please?
by
GU2800XTVS2 Whirlpool.
by
Add a comment
Add your answer
browns41980 will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 51
All Time: 11,032
