Battery Drain after changing old HDD with SSD
I've changed my HDD with a Samsung SSD 850 EVO 250GB and from day 1 I've experienced that the battery lasts incredibly less than it used to do. Battery duration has decreased by a good 30%. I know that for the first couple of days you might experience a sensible battery duration drop but now it has been installed for more than 2 weeks.
More infos about my Mac:
I've replaced the optical drive with the old HDD and combined it with the new SSD into a Fusion Drive.
- RAM: 8 GB 1600 MHz DDR3
- Battery capacity: 5849 mAh (original 6900 mAh)
- Battery cycles: 1251
I've already reset the SMC and checked (using activity monitor) that there was an application hogging the power.
Any idea of what might have happened and how to turn my battery duration back to normal?
2 Comments
Hi Denis,
wow thanks a lot for your response!
Following what you say:
1- I understand that swapping the HDD and the SSD positions will safe me for future possible problems but when you say "go into Startup Disk Prefs to set the boot up to the correct drive", how exactly do I do that?
2- how do I revert my Fusion Dive set up and move to a dual drive consfiguration? And most importantly, how do I set the OS and the Applications on the SSD and the rest on the HDD? Once that is done, when I use a program (for istance Photoshop) will I rather move (temporally) the working files on the SSD for higher or faster performances or will it work smoothly keeping them on the HDD?
I've got another question for you: since the new setup with the SSD, the computer is always very hot and the vents are almost constantly running like crazy.. Is that linked to the Fusion Configuration? Will everything go back to normal with the dual drive config?
Thanks a lot for your help!
by Riccardo Valsesia
Ever had any anomalies with this machine, especially any video issues, artifacts? It is know, on some, to have GPU issues.
by mayer
