Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
My the device doesn't turn on.
Hello all,
I have this issue with an iPhone 5s. The screen went blue a couple of times then after a while the device didn't turn on anymore. I'd like to invest some time and money into trying to fix it, even if it doesn't worth it overall, for the sake of learning.
So, I checked the battery and when fully loaded the voltage seems to be fine. From reading other forums I found out that the main board or the logic board may be the problem. Is there way to diagnose it? I would clearly buy a new one from eBay and try to replace it if that's the case.
Where else should I look? What else can the problem be?
Thank you for taking the time to read this!
Add a comment
Chosen Solution
I would avoid eBay, it's kind of like playing the lottery. I would buy two parts from iFixit
First I would buy this
iPhone 5s Battery
Likely your culprit
You could need to buy this
iPhone 5s Lightning Connector and Headphone Jack
I'm guessing you'll need one or both of those, if it's the board, you'll want to send it out to a repair service, like iPad Rehab
How to replace the battery in your iPhone 5s
iPhone 5s Lightning Connector Replacement
iPhone 5s Battery Image
Product
iPhone 5s Battery
$29.99
iPhone 5s Lightning Connector and Headphone Jack Image
Product
$24.99
Guide
Difficulty:
Moderate
30 minutes - 1 hour
iPhone 5s Lightning Connector Image
Guide
Difficulty:
Moderate
1 - 2 hours
Score 1
Add a comment
Does the phone not turn on or does it not display? Trying flipping the vibrate/mute switch and see if it vibrates. Also try plugging it into itunes to see if it recognizes it.
1 Comment:
iTunes doesn't recognize it. It's fully off :(
by
Add a comment
Add your answer
VRad will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 61
