My dishwasher is showing a sign that says oe
my LG LDF7774ST dishwasher is showing a sign that says oe
@lindav OE is a drain error displayed when the dishwasher is not fully drained out in spite of 5 min. drain operation.
* Caused for that can be :
* The Drain Hose kinked or blocked.
* Wiring connection is OK?
* The drain outlet of sump is blocked.
* The Drain Pump/Motor or circuit is No drainage though drain pump is working properly? Air in the impeller of the drain pump might cause this case.
* Knockout plug of garbage disposal not removed.
To remedy these you want to :
Remove the cause of kink or block.
Check the wiring connection.
Measure the electric resistance of Drain Motor. (20-40 ohm )
Replace the Drain Motor or repair
Remove all the water remained in the drain hose that is connected to the drain pump / motor.
Keep the unit upright, don't lay it down. Cautious about leaking on the floor.
Clean the air gap.
Remove knock out plug.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,730
