Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Bootloop, after replacing back plate, battery, mute - volume up etc.
My Iphone6 is now in crazy state. It's like Schrödinger cat.
After unfortunate accident it did bend a little, so I did have to change few parts, like: Back plate, battery, volume up-down metal plate, whole screen.
Logic board was fine.
Now It really like to reset at random, after a day or two, or after 10 seconds of usage. I tried hard reset, soft one, 2x new battery, calibrate battery, restore to original factory setting, upgrading software etc. When boot looping it's getting hot, and after a short while of working and doing some minor tasks.
What did I notice. Well, if the phone is on cable to power source (PC, charger) It's working better, sometimes doesn't bootloop at all. When battery is in rage of 50%/55%-100% It doesn't looping that much, but still that's big problem. Hard reset sometimes help for while.
Do you guys have any ideas what should I do ? Did I could misplace some small screw in assemble and cause problem ? Is this hardware or software problem ?
I've got some of logs from:
JetsamEvent
Periodic-microstackshot-report
ResetCounter
Stack
and few ForceReset
Add a comment
1 Answer
Have you tried another good lcd assembly? Your aftermarket one could be pulling more voltage than the original causing issues. Or it could have exposed metal causing a short.
I would try another good known screen to rule that out. Also if you still have the original broken one I would hold it side by side to the replacement and make sure everything looks the same.
Also are you 100% certain you put all 4 screws up top in their correct place? If you, for example, accidentally put a longer screw somewhere it's not intended to go you could cause damage to traces underneath.
Add a comment
Add your answer
Slavko B will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 378
