How much memory can I install
I thought I read somewhere that the maximum Ram can be as much as 32 MB. Is that correct?
It's according to which machine you have. There are four EMC 2390s
See them here:
http://www.everymac.com/ultimate-mac-loo...
RAM Type: PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
Details: Supports 1333 MHz PC3-10600 DDR3 SO-DIMMs (204-pin).
Standard RAM: 4 GB Maximum RAM: 16 GB
Details: By default, 4 GB of RAM is installed as two 2 GB SO-DIMM modules. Two slots free.
http://www.everymac.com/systems/apple/im...
Also see: How do you upgrade the RAM in this Aluminum iMac model? How much RAM does it actually support?
Standard RAM: 4 GB Maximum RAM: 32 GB*
Thank you for the prompt answer. I have maxed it with 8 more GB Ram but thought if I can get it fixed that I would add more if possible, seems not.
This is the only one that will not go past 16 GB
Apple iMac "Core i3" 3.2 27-Inch (Mid-2010) Specs
Identifiers: Mid-2010 - MC510LL/A - iMac11,3 - A1312 - 2390
Mine's the i7, I wanted to confirm before installing that much. It does well with the 16 GB and hopefully will continue. I appreciate very much your help.
Make sure your programs can even use the 16GB before going to more RAM.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 386
