Errors with new mother board
Hello to all here I will explain my problem:
My macbook 13 "white in 2008, after suffering a fall a motherboard HS PENRYN 2.1 GHz so I decided to exchange it against a PENRYN 2.4 ghz ...
Unfortunately after all this change did not to the point:
If I take my little MacBook and I'm moving it crashes IMMEDIATELY!
Then there must be a false contact with my keyboard when I pressed it tight as I normally back it does not work! the power button stops responding.
Sometimes it was the ignition is black with LED lights Ventilos running but not against any noise.
I'd like to help if possible
thank you
Update
'm french :( bon je vous explique mon macbook aprés changement de la carte mère a de gros soucis : Dès que je le déplace il bug immédiatement ! Ensuite quand il est eteint j'appuis sur le bouton power la led se met en route le ventilateur aussi mais l'écran reste noire ! Ensuite autre problème quand j'enfonce le clavier correctement dans la coque il ne fonctionne plus !!!
I'm french :(
by rossi
