The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F 06 error code
My washer keeps stopping mid-cycle and displaying F 06. I have tried "rinse and spin" and "drain and spin" but I can't get a cycle to finish.
Add a comment
Chosen Solution
Ralph gave a very good answer on this here:
f o6 error code
@oldturkey03 Gave another one here:
Hasn't somone figured out the F06 error code?
Score 3
Add a comment
The cause of my F06 errors appears to be rust and sediment that is coming from the pipes of a 1968 house. Had to install in line water filters for both hot and cold. This will work for months on end and then F06 returns. Clean out the filters. Clean the filter screens where water enters the back of the washer. There is a small inline device that connects the water supply to the timing box at the front left corner of the washer. I remove the device and blow it out. Back in business. Check the screen filters where your hose attaches to the washer. If there is any rust or sediment, consider in line filters.
Score 1
2 Comments:
yipes. I was hoping it was similar to a draining problem I had (and fixed!) 3 years ago. I was able to access everything by removing the front lower panel. So just clarifying, I need to access the back of the washer, correct? And is it difficult to find these filter screens. Are they easy to spot. Do I need to take something else off to see them?>
by
Time out. The filters are at the water inlet fixtures on the back, top, left on my machine. This cleanout worked many times but never permanently. I have now replaced the motor control board and believe this is the solution. A second hand board worked for me and cost less than $40. The board is located bnottom, left, front on my machine. There are any number of good utube tutorials for this job.
by
Add a comment
Add your answer
Kim Miller will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 30
All Time: 9,787
