A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Controller won't connect in safe mode
Changed hard drives in the PS4 from the 500gb to a 2tb drive, have to boot to safe mode to install the " PS4UPDATE.PUP " from my flash drive and it won't accept any controllers when I connect them...
I switched the drives back and the controller worked fine when running the console but when I booted safe mode on the 500gb drive it still wouldn't accept my controller, it charges from the console but won't connect, the light just flashes white when I press the PS button, could this be faulty hard ware in the console? (Ive tried every micro usb cables on multiple different controllers, with an unpaired controller it wouldn't even attempt to sync, the controller flashed blue till it stopped looking for a console)
Score 5
3 Comments
Have you found the answer yet?
by
My ps5 is doing the same currently..
Madden 23 crashed but all other games are working fine
by
Op here, this was years ago on the ps4 before the ps5 was a thing, sorry to hear that its happening on the ps5
as for the ps4 my buddy had a clear DS4 controller that he used to game on his PC, unclear if its Sony DS4 or an aftermarket controller, but it talked to the console while the Sony ones I had didn't work. id just keep trying controllers and cables until something works
by
Add a comment
Most Helpful Answer
I experienced this as well. It finally required an actual PS4 micro-usb cable purchased at Target for $10. All the other cables I had did nothing. May just be the type of cable…I went with the “official” Playstation usb cable. Smooth sailing from there.
Score 5
1 Comment:
That’s exactly what fixed it for me, too. Went through so many USB cables until the original one finally fixed the problem.
by
Add a comment
I had this same issue and was in total panic. I came across this post and luckily Jeremy had left an answer that was correct. I was at that desperate point that I’d try anything, i tried 25 different usb cables and nothing would work. I went and bought the genuine play station cable and sure as heck it worked.
Score 2
1 Comment:
wow thanks a lot it was simple as changing the cord lol
by
Add a comment
That's kind of a strange one. Here's what I would do...you don't actually have to boot it to safe mode to install the software. Just put the replacement hard drive in then start it up. It will prompt you to put the USB drive in, then you can install from there. See if that works.
It's possible that it's faulty software on the console but I'm not sure I've ever seen anything quite like that.
Hope this helps.
Score 1
3 Comments:
Thanks for the response, but It just boots safe mode and says the PS4 can't start when I try to just turn it on, it then prompts for me to hit the ps button again with the controller plugged in, and still remains unresponsive
by
That's strange...when you put a new hard drive in it should ask you to insert a USB drive with the system software on it. I haven't seen one before that doesn't do that. I'm guessing it must be some sort of software issue but it's hard to know for sure without begin able to test it myself.
by
I'm having that exact same issue... it seems like it's becoming a more common issue. I have an original PS4 controller and the newer PS4 controller (and I've tried 5 different cables). I wonder why I can't install and load the system software.
by
Add a comment
Lot of charging cables are only output cables and does not provide input back to console when you press ps button. You need to buy a data cable which takes both input and output so that when you press PS button it register input and send it back to console. Hope this helps
Score 1
1 Comment:
Do you have a recommendation on what cable to get? no one ever says.
by
Add a comment
My ps4 says it can pick up the updated file on my external hard drive and I've tried everything do I have to send it back to the manufacturers to see if they can help with the problem
Add a comment
Add your answer
rowanwelyk will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 70
All Time: 35,564
