Will the 2010 15" MBP HiRes Display Work With the Mid 2009
I Know the entire mid 2010 MBP display is not compatiable with the Mid 2009 15" MBP for a fact, just because it has different connectors/moduels when it comes to bluetooth/airport/iSight.
But i think its possible to replace the mid 2009 (1440 x 900) TFT LCD display with the one use in the HI-Res mid 2010 MBP (1680 x 1050). I think it is simply just a higher res TFT LCD. I mean it might be a pain to removed the glass from the display assemble, but I think you can install a LCD panel with a higher resolution such as the one used in the mid 2010 Hi-res model.
Can anyone tell me if this is possible? I know you can get the LCD panel but will it be compatible? will the graphic processor handle it?
Will the mid 2009 MBP recognized the higher resolution LCD display panel?
