Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
broken I phone came alive (well, partly at least)
two years ago somebody gave me there iPhone 4 that was dropped into a toilet and never gave any sign of live ever since. she wanted to true it away and i just said to give it to me since i just like to fool around with old or broken electronics and search for what still can be used.
i forget about it, but came across it two days ago, and thought "maybe all the water dried out of this thing, maybe it will work",i didn't had any hopes what so ever for it, but i had a charging cable laying around and plugged it in "nothing to loose".
after a few minutes i heard and felt it vibrate. i unplugged it, plugged it back in and again, after a few minutes it vibrated. i left it charging for a few hours when i came back i unplugged it ,tried to turn it on, but no reaction. when i plugged it in again i made this "ploing" sound. i decided to let it charge a while longer.
now it vibrates when i turn off the silent mode, it makes the sound when i plug the charger in, but the screen doesn't do anything really. unless i try to force restart the phone then i see, very weak the apple logo.
what does this mean? is only the screen dead? would the phone be "normal" again when it is replaced? or is it something else?
can somebody please help to diagnose this iphone further?
Score 1
4 Comments
so, no body has a clue?
by
@har looks like it
by
thats a pity...
by
I have had the exact same problem and I was wondering if I should just replace the LCD and the digitizer works to. I don't want to replace it if it does work correctly. You know
by
Add a comment
1 Answer
Chosen Solution
@har, hAR, I think you should have some fun with that iPhone 4 after all it was a freeby.
Stop charging or powering up your device until the liquid damage is addressed correctly, as you could be shorting out components inside the phone. You really should take care of the corrosion that is happening inside the phone from the water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the phone to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the phone and see if further damage has to be addressed. The 3rd link is to a lot more disassembly guides and info. that may help in your repair. Good luck.
iPhone 4 Logic Board Replacement
Electronics Water Damage
iPhone 4
Score 2
Add a comment
Add your answer
hAR will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 62
