2.2, 2.4, 2.5, or 2.6 GHz Core 2 Duo processor
939 Questions View all
Will MBP15 run without LED installed using xternal monitor?
I have a MBP 15 a1226. Had a cracked screen that I've taken out. Can I run it with an external monitor? I have an apple cinema display I'd like to use. I've had the motherboard out and cleaned everything up. How much do I need to reassemble? I have the whole bottom tray section pretty much done (except bezel) but don't want to leave any open loops etc.
Thanks -mike
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
I should think it would work just fine. Leave the connections to the LCD unconnected. You will I think lose airport and bluetooth I think because their antennas at least are in that part of the laptop. I would think the simple test would be to assemble the unit without the LCD and see if it runs. Good luck.
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Display Assembly Replacement
Score 2
Add a comment
Add your answer
Mike McIntosh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 638
