Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Charging port replacement options
Can you change out the charging port in a Samsung galaxy s5 with the charging port from a Samsung galaxy s4 active?
Add a comment
1 Answer
Chosen Solution
@rowdyrebel , Kimberly, the charge port assy. differs from the S4 and S5, Links below to show the difference, also a how to write up on changing the S5 charge assy. and where to purchase the charge assy. for S5, which you can also do a search for for better pricing( always verify with seller to ensure you are getting the correct part for your device). The last link is solely the port which would require some micro soldering by some one with experience in this field. Good luck.
Samsung Galaxy S5 Charging Port Replacement
Galaxy S4 (Sprint) Charging Assembly
http://www.ebay.com/itm/Samsung-Galaxy-S...
Galaxy S5 Charge Port
Replace a broken or damaged charging assembly for your Samsung Galaxy S4 smartphone with this part. This assembly includes the charging port, USB, and cable assembly. Image
Product
$12.99
Replace a dirty or corroded Micro-B USB 3.0 port for a Samsung Galaxy S5. This part requires microsoldering. Image
Product
Score 2
Add a comment
Add your answer
Kimberly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 956
