Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
OEM LCD Screen freeze after snap into back housing.
Need help with all the expert from all over the world.
i been fixing iPhone 6 since the next week it came out.
Now i have a new issue. I myself refurbished OEM LCD and i only use OEM. not after market.
So what happened is this iPhone 6 freeze whenever you snap completed assembly LCD into the phone and it always working Ok before you snap in it.
No ghost touching. just freeze.
So i thought it might be because of the back metal plate and the LCD flax cable plate cover.
I took off the plate cover and i changed LCD back metal plate as well. but it's the same. the original metal plate has broken and it doesn't work with figure touch ID.
i even change the whole back housing and transfer every single pieces from the original phone. because i though the metal plate touch board and short due to the bent.
i was thinking, it has short somewhere left side near volume button and below.
I wanted to get advice from you all.
Like i said, it's always working OK before you snap into the phone. and i am 100% sure that my LCD doesn't have a problem. because i tested with 3 different LCD. all OEM. all 100% work with the others board.
Add a comment
Chosen Solution
It's fixed. But sadly cant snap the top part all the way in.
Can't put the LCD flex cable connector cover as well.
Looks pretty ugly. I temporary used wire tap to cover the gap.
I tried with whole LCD assembly from others phone and the same thing.
Score 1
Add a comment
Could be damage to the digitizer connector or the cable itself gets bent when pushed in all the way. Definitely a weird one.
Do you have any exposed metal contacts on the screen assembly that could be causing a short when closed?
3 Comments:
I will have to double check it. It's pretty weird. Looks like i am the first person with this issue :)
Today i am gonna try with the whole new LCD assembly from different phone and test it again.
by
I think is the best to test the lcd on different phone and then put it into the one you have trouble with and see how it goes :) Good luck definitely strange one :)
by
@Mimi i did with 3 differents lcd. But i will test today again and let y'all know
by
Add a comment
Add your answer
PETER will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 119
