Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
phone screen flickering and/or vertical lines
The phone screen alternates between flickering in a light magenta shade and displaying vertical lines. Phone is completely usable, just now with shades of color tossed in the mix.
Sounds to me like a damaged LCD cable, but I haven't taken it apart yet. I've worked with electronics repair, just not iPhones. Point me to a guide?
Score 1
2 Comments:
Once any LCD cable or LCD gets damaged you pretty much need to get the screen replaced.
by
my phone has lines and is glitching and has green spots on it. I have the 8plus
by
Add a comment
You may need a new screen or take the screen off and examine the connection cables of the ribbons and mother board. If the brass teeth are not perfectly aligned GENTLY drag a razor blade tip along then to realign them and CAReFULLY reconnect them
Add a comment
This could just be down to dirty contacts, you can try gently cleaning the contacts with a toothbrush whilst checking if any of the contact pins are bent or not aligned, you have to be very careful not to damage any of the pins.
Add a comment
Took phone into Telstra and even they were dumb ass dumbfounded finally gave me new phone but I want to fix the other
Add a comment
Add your answer
Thor Kamphefner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 13,506
