Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
iPhone 6 Plus tristar replacement
Hello. I have iPhone 6 Plus and I replaced tristar to it. Before repair I tested it with multimeter for how mutch USB cable give power to the battery bracket on logigboard
and the volt was 0.01v and with new tristar the battery bracket gived random volts wery fast 3.50v, 2.45v 1.20v etc. Do anybody have any ideas what is going on? Before repair iPhone wasn't charging or warming at all and no powered on. Screen was black and still is. I have reflowed it without any results.
Any help would be much appreciated.
EDIT 01.08.2017
With new good battery and tristar reflowed once again the iPhone works again.
Score 1
Add a comment
Is that with the battery plugged in? Maybe it isn't sensing the gas gauge circuit and dropping the voltage.
6 Comments:
No, the battery wasn't plugged in when I tested the bracket with multimeter.
by
Take the gas gauge circuit off an old battery and hook the multimeter to the circuit prongs that go to the cell. Then plug it in and try and charge it, the voltage should be around 4.2v
by
Ok. Now I tested the voltage with battery. With USB cable and without USB cable. With cable it show 2.85v and without USB cable 0.65v.
by
Sorry I dont know what "gas gauge" means.. heh. My English is not so good :/
by
The gas gauge is the circut between the battery cell and the logic board, it is the bottom 0.5cm of the battery. You can get it off, but make sure you don't puncture the battery.
by
Show 1 more comment
Add a comment
1st the TriStar is not a charging IC it is a high speed switch that switches between vcc main/vccbatt it also switches cpu and baseband hence the name tri. Tigris is the charging IC. TriStar requires three voltages to function, a reverse gate handshake pin power in. If you have schematics and tools I will help you tomorrow when I am in work
2 Comments:
Thank you for the information. But I already replaced the tristar and now the iPhone works. Thanks
by
can you tell me how you solved this problem to get phone to work please
by
Add a comment
I have iPhone 6s Plus
Its never charges after 87%, charging very slowly and battery quickly draining
What’s the reason for this problem?
What I do?
Update (01/22/2018)
yes. I already charged 3 batteries and chacked but it’s never charged fully
Never charging after 87%
2 Comments:
You need to try a new battery first.
But usually slow charging and very fast draining of battery is synonym with short on the board. That would have to be considered next after trying a new battery or at least testing it with "coconut battery."
by
I had the tri star replaced on my iphone 6s plus..now it won't power on at all any suggestions.
by
Add a comment
Add your answer
Mobilefi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 2,694
