Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1704 Questions View all
Why my refrigerator stops working and not getting ON again.
I had a refrigerator whose specifications are as belows
Make : Videocon
Capacity : 180 litres
Supply : 230V, 50 Hz Ac
date of purchase : 2 apr 2007
As soon as i start supply of my refrigerator it switches ON and after almost 4-5 minutes it switch OFF again and doesn't switch ON again. During the ON period (4-5 min) it does not have cooling effect.
Please tell me the possible causes of fault.
Thanks
Shaikh Sohail
Score -1
1 Comment
Thermostat know is set properly.
The compressor starts running when i turned ON the power and after 4-5 minutes the compressor stops and the refrigerator also stops. And now if i unplug the supply and again connect (switch ON) then same thing happens.Compressor gets start for some time and again gets OFF.
by
Add a comment
1 Answer
Chosen Solution
Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, I recommend contacting a qualified appliance repair technician for further help.
If you can give a more detailed description of the problem I might be able to give you a better answer.
Score 3
1 Comment:
good answer +
by
Add a comment
Add your answer
sohail will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,445
