Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 Questions View all
MPB shuts down shortly after turning on, halfway trough the status bar
My MBP has been working fine for years now. There was no change, dammage or anything else done to it. Updates were done regularly. All of a sudden, shortly after turning the MBP on, it would shut itself down halfway through the status bar, everytime i try.
After a long research on the web, no answers. Going to an "Apple Authorized Service Provider" they went trough everything, but starting up in "Apple Harware Test" and also in "safe mode", showed no sign of problems. NO answers there.
I tried to get hold of my latest data, and by chance i found out, that by holding letter "D" constantly from starting up, the MBP would not shut itself down, but run just normal, no safe mode, no harware test, just normal. I could backup all data and restore the MBP to factory settings (while holding letter "D" all the time).
Despite everything, unless i keep holding letter "D", MPB shuts itself down.
Any help?
Add a comment
Chosen Solution
Plug in a hard drive via USB port (with Mac OS installed) and try to boot from this
If it boots, will just need either a hard drive or cable
If not, will be an issue with the logic board, probably one not worth fixing (GPU related most likely)
Score 3
1 Comment:
ok, thanks for your help! i took me a while, searching for tech help and apple officials that might know something, but no, no answers at all. i ran a test again, this time it worked, don't ask me why.... here's what i got: picture below
by
Add a comment
does that help in any way?
Add a comment
Add your answer
i s 16 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 75
