Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
426 Questions View all
How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
Score 2
6 Comments
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
by
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
by
cant get it to work either way.what to do ?
by
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
by
I've got it working, see my answer below.
by
Show 1 more comment
Add a comment
Chosen Solution
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
1 Comment:
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
by
Add a comment
Most Helpful Answer
On your RCA tablet go to settings, click on display and then configure HDMI settings.
Score 1
1 Comment:
What do you do after or even how do you configure HDMI settings
by
Add a comment
Add your answer
boogityboo will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 13,077
