How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
On your RCA tablet go to settings, click on display and then configure HDMI settings.
What do you do after or even how do you configure HDMI settings
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 13,077
6 Comments
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
by boogityboo
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
by boogityboo
cant get it to work either way.what to do ?
by Wess Reddish
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
by jillherbert1
I've got it working, see my answer below.
by jillherbert1
Show 1 more comment
